SOURCE: My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON
2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
SOURCE: need a universal remote control code for Hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
SOURCE: code remote control universal hisense LHDN32V66AUS
Hello
Four digit universal remote code for Hisnse TV are:-
0073 0182 0216
Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
