2008 Yamaha YZF-R15 Logo
Anonymous Posted on Sep 14, 2012
I have Yamaha R15 v1. Normally my bike's radiator used to run itself after 30 min of time. But recently it has stopped working..my engine gets real hot..still it does not work..whts the prob??plea
5 Related Answers
Anonymous
  • Posted on Nov 20, 2010
SOURCE: sir, im having yamaha fz16 bike... the
notin can be done dude.. its a major fault u can see in all FZ's.. My engine smelled really bad in 1st two days...
Anonymous
  • 21 Answers
  • Posted on Mar 18, 2010
SOURCE: yamaha r15 the engine misses at low rpm and at sudden accelerati
dirty carbs or fuel filter
Anonymous
  • Posted on Apr 19, 2009
SOURCE: On Yamaha wr450 dirt bike the exhaust pipe gets
Sounds like you are running waaayyy too lean. Aftermarket intake/air filter/exhaust?
Anonymous
  • Posted on Sep 07, 2009
SOURCE: radiator fan in not working even when i can feel
the radiator operates at 90 degrees and above so dont worry it is an expected behaviour
Testimonial: "thanx fr yr kind consideration ..."
Anonymous
  • Posted on Jan 03, 2011
SOURCE: I am facing some problem
i am facing start problem with my yzf r15
My R15 v2 YZF engine light blinks 10 times firsts 5 blinks slow rest very fast bike tends to stop whenever it appears n stop but when the light is on upper the bikes dont stop above 90 km/hr not stop
Yamaha yellow blinking light start Motorcycles Questions ...
www.fixya.com > ... > Tags > yellow blinking light start > Motorcycles
Ad. Question about 1997 YZF 750 R ... oil light blinking on 2004 yamaha r1 oil lightblinks 10 times stops then blinks 10 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
Yamaha blinking yellow light Questions & Answers - Fixya
www.fixya.com > Forum > Tags > blinking yellow light
oil light blinking on 2004 yamaha r1 oil light blinks 10 times stops then blinks 10 times ... Question about 2008 YZF-R15 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
[Ownership Thread]: Yamaha YZF-R15 - xBhp.com
www.xbhp.com/talkies/.../4854-yamaha-yzf-r15-1951-print.html
Jul 11, 2013 - 4 posts - ‎3 authors
2months back i got this problem while riding the engine goes off, but ... of heavy traffic after transporting it from my home town. then it works fine and all of a sudden i find the bike engine light blinking. it reads '42'. then after showing it to ... the ECU alone wil cost me to 10k. and obviously it is very expensive ...
Yamaha YZF-R15 version 2.0 - xBhp.com
www.xbhp.com/.../20138-yamaha-yzf-r15-version-2-0-a-786-print.html
Nov 26, 2013 - According to me the problem of chain with my bike is because i ... list about the required changes at 10k kms like Fork oil change and ... On switching on the ignition, the engine malfunction light, the orange(?) ... From your description that a longblink coupled with 3-4 short blinks it .... All times are GMT +6.5.
Jan 27, 2016 • Motorcycles
, i am using yamaha r15 bike .i recently filled up coolant oil on ur advice as my bike radiator is heating too much.But after refilling my coolant oil i observed the coolant oil is leaking(green colour...
Yes.. This is the same and exact scenario on my bike R15 v3 bs6... I too topup my bike with coolant on before filling the coolant oil there is no leakage, only radiator fan will run, after filling results coolant oil leaks from the radiator fan.
kindly suggest any solution plzz
1helpful
Hi, i m using yamaha r15 v2 .i got changed my coolant at 9k km but now my bike had crossed13k km mark..but the coolant is full nd when i drive with in 5 mins the red light turns on and the radiator...
Okay, first of all, you got a get a manual on your bike. They've got a drainer Rady Ater and flush the system. Follow the directions that he had to put the proper amount of fluid back in the unit, make sure there's no air pockets and is probably away to turn your sensor light off after doing this the engine oil has nothing to do with the radiator
1helpful
3answers
My r15 radiator fan is not working properly
Hello. Start your bike and let it idle for 10-15 min. Check the radiator fan, it should start running.
You cannot check if the radiator fan is working or not at random timings as the fan gets ON and OFF depending on the engine heat. (I got myself confused as my Bike's radiator fan was not alive even after a 100 KM run).
Happy riding with your R15!! Take care.
My yamaha r15 stops because it is getting discharged on running
I have same problem. I was going some where and bike was not running smooth. Sometimes it was giving JERK. After some Kilometers it stopped suddenly after giving Yellow light. Then i tried to start it after 15 minutes it started. Service person changed charger but problem is still there.
Can anyone tell me the reason?
My mobile is 09889271602 please message me or call me its request.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
