I have been trying to find a supplier for a Tunturi T85 treadmill circuit board. The manufacturer recommended distributor in Canada hasn't answered their phone in a month and I fear they are out of business.
Here is a parts list for the Tunturi T85 with many available parts. I don't see a circuit board but you may be able to contact the company to see if it has a different name or if they can get it added.
I have got brand new t85 treadmill power board if anyone wants to buy it.
Hi, do you still have the power board
Yes I still got tunturi t80/t85 power board contact me 447943858686
do you have a t60 power board?
Is the T85 power board still available?
SOURCE: hi i have a code E7 that show on my upper board in
Pull the connector off the incline motor off then connect (usually red and black thick leads) your multi - meter then select ohm X1 you should get a reading about 1.7 ohms. then check if the motor see if it is stuck. Then wrap a peice of cloth around the incline screw and with a pair of vise grip gently apply enough pressure to see if you can unstick that screw, reset your power and if the error code clears up, if not the VR control in the motor can be defective and you must rplace the motor.
If the reading show open I would suspect the motor is bad then again replace of the motor.
SOURCE: Looking to buy a good quality treadmill for home.
Tunturi unit have been always a reliable unit and they do not have very many problems. I like and sell the Sports Art products for five years and they are reliable and sturdy units, at one time they were manufacturing for Tunturi and other highly visible companies in their 30 plus years in the industry.The only worry is, do you have a reliable service company that will take care of you if whatever product you choose to purchase. I know as a servicer I rely on my vendors to give me great service so I intern give great service to my customers.
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
