I bought a gas stove from an individual and it is very clean and everything, but we have a yellow connection and my contractor told me that it was for propane stove and not natural gas. Is there an adapter for a Gas stove nasturel that I can buy to convert to natural gas. My model is a Kenmore 970-337480 thank you Lorraine
Hello Lorraine,
Most gascookers heve the possibility to change from LPG to natural gas.
You need to change the injectors. The holes in the injectors for LPG are smaller that the ones for natural gas.
I send you a link of Ebay where you can see what you need to look for.
Sometimes the oven can give a problem when it is gas too.
Kind regards, Dik
14results for natural gas cooker nozzles
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
SOURCE: Thermador PG484GGBS: How to convert from Natural Gas to LP?
I just did it with mine, I called thermador and they told me the number of the conversion kit to buy for my model.
I bought the kit from the retailer and did it myself, not very difficult.
no explosions yet :)
nic
