I recieved the psp last night and everything was working fine. I went on psn and downloaded some wallpapers and a demo. Now today when I try to go on psn I get a cannot fin access point and to check security settings. I have not touched any settings and did a restore default settings. If anyone has a clue in how to fix this please give me a heads up, thanks.
SOURCE: PSP Internet Problem Cont'd
Dont forget to check your WLAN switch on the left hand side, it must be slid to the up position.
SOURCE: My PSP can no longer connect to the internet.
ok change the encryption type to WEP and then for security try to enable mac addressing. try it in a web encryption. if this wont work then you will have to install the net connect software
SOURCE: PSP won't download movies from PSN
you if you go www.psp-hacks.com you can download the 5.03 and then it will work fine
SOURCE: my PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
