Kohler 20resa 20kw Home Emergency Backup Generator Logo
Mark Bronson Posted on Sep 14, 2012
Is there a software problem with 20RESA?
Does the software run the generator at 3600rpm instead of 1800rpm?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
228
Points
2answers
I have kohler 20RESA generator. I cannot clear the fault that says "engine m/n invalid shutdown". Can anyone help with this? I did go through the reset procedure, but fault reappears immediately.
Emergency shutdown operation is required when one of the above conditions occurs in diesel generator set.Diesel generating set itself has an emergency stop button, at this time, press the emergency stop button or quickly press the stop control handle of fuel injection pump to the stop position, the diesel generator will quickly cut off the load, and immediately close the throttle, while the red "emergency stop" light is on. Need to press the button again to delete the emergency stop signal. If there are serious faults or distribution faults, you can also press the button on the control panel, and the unit will stop immediately.
In fact, all faults always give operators some warning signal before spare parts break down or engine damage occurs. So the operators need to be smart, and notice alarm signals (sudden drop in oil pressure, abnormal sound, etc.) and immediately stopping the engine.
Emergency shutdown operation is different from normal shutdown operation.
Emergency shutdown operation.Once the operator finds that there is a serious fault or distribution fault in thediesel generating set, he can press the emergency stop button of the control panel to stop the unit immediately. If there is no special circumstances, we advise users not to stop the unit at will through the emergency stop button.
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
Have generator showing emergency stop code and will not start.
there are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
Why won't generator idle
is it running eratic, load or no load ,they are normaly set to run at 3600rpm at this speed they will make their correct voltage
Downloading generator data direct to a PC
No there is no way to do that unless you are a Kohler dealer, and have their service software, which is only available to dealers. It is called KOloader.
Service manual 20resa
Contact Nixon Power Services in TN they can get you one
GEN SET WILL NOT START /MAIN POWER OVERLOAD
I have a Generator Kohler Res14 and its not crancking, and error of invald shutdown
Generator is fast running and has blown 2 power tools and cement mixer
Use a meter and adjust to 3000/3600rpm or 50/60Hz. Then check output voltage to be in range 230/115V depending on which country you are in. Adjustment is done on the governor to throttle linkages.
I have an older 30KW Generac SG 030 1800rpm running on Nat Gas which I bought used. It has set up for several years. I installed a new PN0830890SRV master control board I bought from the local Generac...
need to calibrate the main control board. 83089. also is it overspeed or overcrank? if the board does not see the right rpm or is blow a certain threshold it will think it has not started yet and shut down on overcrank.
2helpful
Engine running at 3600 rpm i get 0.51 volt reading from all scocket outlets
check your volt-meter..if it works...then find out if 3600rpm is normal for that kind of generators...if so...check AVR card...its allways the problem...replace it
i hope i helped...send me an email for more details
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
