Why does my hand wheel screw on my Necchi serger pl1036 keep working out? and how can i retime it when it does? it will be working great then the screw falls out, which makes everything all wonky. i have managed to retime it once before but it took forever
SOURCE: I bought the tiny singer serger second hand for
I hate to say this, cut your losses and get rid of it.
SOURCE: Necchi PL1036. Needle bar worked loose and slid
Oh dear..... Bent looper and needle arm loose... Take this to be repaired before you damage the other looper as well and it costs twice as much. Expect looper to be in range of $65 plus service, as a ballpark. There are many variables with overlocker timing and it is beyond the scope of either this forum or the novice to correct the problem I am afraid.
SOURCE: the hand wheel keeps falling off and now when i
If the balance wheel is coming off which it should not do because it is held on by the belt then you have not tightened the stop motion in the middle of the balance wheel, make sure you have not lost the little screw in the middle if the balance wheel.
SOURCE: I have a husqvarna serger 936 and I can't get the
You probably are putting the needles in the wrong holes. The two holes you want the needles in for the basic overlock stitch are holes C & D which are to the FAR RIGHT SIDE of the needlebar not the main 5 hole piece that you see first. These are used for the cover stitch only. When you insert your needles (flat to the back) or remove them MAKE SURE you tighten up the screw immediately so you don't forget to do it. If they are loose and fall down in your machine good luck finding them! Hope this helps you.
