General Electric 65-Pint Dehumidifier ADEW65LP Logo
Anonymous Posted on Sep 13, 2012
GE Humidifier smells terrible
We bought a GE humidifier [ADEW 65]. It does a great job of getting moisture out of the air. After about a week, it started smelling terrible!. I removed the bucket and the removable filter. I washed each in warm, water with some dish washing liquid mixed in. Let them dry, then re-assembled and plugged it back in. This did not solve the problem. Any suggestions?? Thanks
Frigidaire dehumidifier has an error code of EC and does not take in any water. The temp in the basement is a constant 68 degrees.
First, I'm not a Frigidaire tech.
* Check your warranty. Call for service.
* Contact (note Live Chat link); https://www.frigidaire.com/Owner-Center/Contact-Us/
*** following is for information only ***
* Checking basic problems; https://www.youtube.com/watch?v=SXJrVGP_Ixs
* The humidifier will only run if the "Humidity" (water or moisture in the air) is higher than the current setting on the humidifier. If it's set to maximum dry setting then expect it to run almost 100% of the time. If it is set to a "wet" setting then expect it run only for short periods.
* Colder room temperatures will reduce the frequency of cycles as cold air will hold less moisture than warm air.
* You may note that running a AC unit in the same room as the dehumidifier will give you mixed results as both units will "fight" or work against each other. Humidifier will heat the air as it exits while the AC will cool the air. Best to not run the AC while the dehumidifier is in operation.
* Note that AC do "dehumidify" the air as it passes through. But not as effective as a dedicated dehumidifier.
* Be sure to check the tub and filter (make sure they are seated properly.)
* Contact Frigidaire or your local Appliance store for service.
Aloha, ukeboy57
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Cold air is coming out, instead of hot air. how can i fix problem thanks john
if you want hot air the you need a humidifier, it puts warm moist air into the room. used to put moisture in the air if your running a wood stove
1helpful
I bought a Kenmore dehumidifier a 2 weeks ago and it sounds like it is going to come one but then goes off - listening to it right now and it has been doing this for the last 15 minutes. Is this normal? ...
If you bought it 2 weeks ago, take it back and get a new one. A humidifier works kind of like an air conditioner, but a humidifier runs a larger Delta-T across the coil. In laymans wording, an HVAC unit might have a temperature split across the coil of 20 degrees where the temperature split across a humidifier might be 40 to 50 degrees. The reason for this is with a larger Delta-T, you are able to drop the air temperature across the coil and by doing this, your basically wringing the water out of the air. Because of this, it has safetys that a standard HVAC unit would not have. It usually has 2 low pressure switchs rather than one and it sounds like it might be tripping on one of them from lack or airflow or a low charge. Take it back and get a new one!!
Just bought, brand new. where to put water in? unit will not turn on.
If you bought a dehumidifier, you will not need to put water in it. A dehumidifier removes water. A humidifier add moisture to the air, and you need to add water to this. Was your dehumidifier running before and then it stopped? If so, it will have a tank on the bottom that will have water in it that needs to be emptied out. Let me know if this is your problem.
1helpful
2answers
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
4helpful
I NEED TO KNOW WHAT PERCENTAGE MEANS ON A DE-HUMIDIFIER
In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
Humidifier Fan Doesn't Stop
RH at 70 % seems to me a little excessive you really should be working somewhere around 50 to 56% the fan has to move Air through the system.
I would like to know your room Air temp what is the Air temp comming off the system. what are your parameters.
2answers
Top GE Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
