The 4 pack up outlet have no electricity and look like dead but the other 4 is working
Did you use quick-connects on back of device?
Copy following link for wiring illustration:
http://waterheatertimer.org/images/Wire-2-outlets.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Check to see if the toaster is plugged in; if it is, unplug the toaster, then plug it back in again.
A tone will sound when the toaster is plugged into a live electrical outlet.
If no tone sounds, check the electrical circuit the toaster is connected to -
is a fuse blown or a circuit-breaker tripped in your home?
At least with "unplugging and plug it back again in the electrical outlet" the right side of our toaster works again. The tone that should sound with plugging in didn't work...
