Lenovo ThinkPad Z61m Notebook Logo
Posted on Dec 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to use my phone as a modem
Hi,pls help me on how to use my phone as modem(connect to internet).
alternatively you can help me to get the correct card taht we put on the left side of the laptop for intermet access.
tahnx
Anonymous
Level 3:
  • Master 700 Answers
  • Posted on Jan 01, 2009
Anonymous
Master
Level 3:
Answers
700
Questions
Helped
306892
Points
1781
You need a att 3g card for you Laptop? I have a att one that works and just needs a sim card and then your on 3g baby. Email me if your interested. Im at gmail and my name
1helpful
HI CAN I USE SIM CARD FROM MY PHONE TALK TALK MOBILE AND USE IN MY ASPIRE ONE
Hi,as far as I know your ACER does not have a SIM card slot thus not capable 3G Data / GPRS connection..however if you have or obtain a
"USB GSM GPRS EDGE Modem for Internet
yes you can..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
What is USB GSM modem?
USB GSM modem is a modem working for cellular gsm networks.
USB GSM modem contains usb gprs modem and usb edge modem.
It's a USB internet modem. Simply speaking, it's just for internet connection.
Normally, we can call GSM modem a 2g modem, GPRS modem for 2.5g modem, and EDGE modem for 2.75g modem.
USB GSM GPRS modem works with GPRS network, back compatible to GSM network.
USB GSM EDGE modem works with EDGE, GPRS and GSM networks, providing 384kbps internet data speed.
http://www.szelins.com/USB_GPRS_EDGE_Internet_Modem.html
2answers
Hi I'm trying to use my desktop pc with ASUS P5Q3 Deluxe Wifi AP @n motherboards onboard WLAN as an Access Point to my Nokia X3-02 phone for WLAN. Would be nice to use same internet connection through...
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect to your phone
hope this helps
10helpful
2answers
I want to use internet with my pc but who software give me with phone,he is not supporting pls sugest me
Hi, To use your phone as modem for internet connection, you should: - Install the pc suite of phone in pc - has gprs capability of phone - register your phone on your service provider for internet connection. Please contact your service provider to make setting on your phone.
It is easy and fun.
Regards, Jay
2answers
I have a WCG200 linksys but can not go onto internet.
from what i have read, your router is broadcasting a signal, and your modem has an open and active internet gateway.
pls make sure that the connection from the modem to the router are correct. the modem should be connected in the port with the label internet. you may have to reset your modem AFTER you have connected the wireless router to allow the router to be assigned an ip. now with the wireless router and broadband modem connected, you can connect to the network and access the internet. pls repost if you hit any snags
GOOD LUCK and PLS rate this post.
China n95 mobile connecting to internet thru usb cable
connect your phone to the computer and choose com port. install the drivers. you also need to install the usb modem driver. then set up new dial-up connection with this modem, no user name or password and the number to dial is *99#
3helpful
6answers
HOw to get internet
Do you have PC suite for your mobile. You need to have software CD for your nokia mobile. Once you have the software, you can connect your mobile to internet. PC suite application has options to connect your mobile to internet.
Download it from nokia site. Sure, you will get it.
Dial up?
Technically no, not unless the PC where the modem is connected to is used as a Gateway/Share Internet Connection and is connected to the WAN side of the router. However, this arrangement would need a lot of manual configuration and settings on the modem side PC as well as the client PCs.
Alternately, you may be better off connecting the modem PC to a hub rather than a router and set static IP adds on the client PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Call drop out after 5mins 30 secs
Hi Youradickhead, I have experienced similar problems previously with Telstra and it was not due to the D-link as far as could verify. It seemed to me that Telstra was able to detect that you were using your internet connection for phone conversations and drop your line. Alternatively it may have to do with the filters that they provide. Try it without the filter, i.e. connect your modem cable straight into the socket (cable port).
Cheers.
Bridge mode
i see,, seems your router is not configured, you can try an alternate way.. if you have windows xp, goto control panel select internet options, goto to connections tab then click set up button a wizard will pop up, click next then select connect to the internet then click next, select set up my connection manually,, select connect using a broadband connection that is always on then finish...
Linksys Modem
To confirm that your PC is connected to the router, open a browser and type 192.168.1.1; In most older LinkSys routers, the default username is none/blank and the default password is "admin." Most current Linksys routers,  the username and the password are  "admin."  Once inside the configuration page, click on "Status"; Verify that your Internet Connection has got some numbers such as IP Address, Subnet Mask, Default Gateway, DNS & MTU.
If none, your router cannot connect to the cable modem, if yes, pls post back the numbers/details. Further, pls add brand/model of your cable modem and your ISP.
In the meantime, you may have to check that all the cables are correctly plug in and that your cable modem & router are getting power from the mains.
Hope this be of some help/idea. Pls post back with additional information.  Good luck and kind regards.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
