Question about Jamo SUB 200 Subwoofer
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
Would like to know how to wire my jamo 200 sub and jamo speakers to be able to use my ipad
  • richardskelt
    richardskelt Sep 13, 2012
    i did that but there is no sound coming out the speakers i can hear sound from the sub
  • 28 Answers
The easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Posted on Sep 13, 2012
SOURCE:
  • 19 Answers
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Posted on Apr 03, 2009
  • 133 Answers
SOURCE: No Sound from Jamo E6 Sub
More likely there is a bad solder connection or a bad connector contact inside the unit, could also be a blown or dried up electrolytic capacitor.
Check the line signal input plugs, if they are soldered directly to the board then check the solder around the pins - if it has circular cracks, you need to resolder the pins.
Also check any other components on the board for such cracks on the pins, including internal connectors, disconnect, clean the pins if necessary and reconnect them.
If any electrolytic capacitors have a bulged top, they are blown and need to be replaced.
It could as well be something else, but your description suggests either a fault at the input connectors or some trouble with the input signal level sensing circuitry (no signal to the sensing circuit may be caused by connectors, no response from the sensing circuit may be caused by bad capacitors or other faulty components in or around that section).
Hope you can find out what it is and fix it...
regards
3rq8 (Triarcuate)
Posted on Sep 11, 2009
  • 127 Answers
SOURCE: my jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Posted on Mar 03, 2010
  • 127 Answers
SOURCE: What stereo amp to be used with jamo s606 speakers (2.0)?
For PC music ( I suppose mainly mp3) you don't need any extra-quality amp, any older Yamaha stereo amp will do. I don't know which of them are available in stores near you, but if you write some model numbers I can check their specs and advise more.
If your PC has spdif output (coax or optical) go for amp which has digital input available.
  • 137 Answers
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Posted on Apr 20, 2010
I brourt a jamo sub 200 and five a102speakers but
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Aug 31, 2014 | Audio Players & Recorders
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Oct 26, 2013 | Jamo SUB 200 Subwoofer
Hi! I have purchased a JAMO S608 HCS 3 and a SUB 650 using an OKYO TX-SR508 Receiver. I can't set it up correctly. When I played music I've heard a lot of bass, I think there are some high...
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
Sep 08, 2011 | Jamo SUB-650 Subwoofer
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
What do the phase and cut off controls do,manual does not explain much.
Phase reverses the polarity of the driver so it can be matched to the other speakers and bass-reinforcement characteristics of its position in the room. You don't want the sub 'sucking in' while other speakers are 'pushing out' or a bass cancellation will occur.
Set it, listen to bass from your normal seating position, reverse it and observe if the bass gets subjectively better. Leave it in the 'better' position.
Cutoff is a variable for the highest frequency where the speaker 'cuts off'. You can experiment with adjusting it for what sounds to you like the smoothest transition betwen the sub and the othere speakers. You don't want a lot of audible overlap where the sub and other speakers are acting on the same frequencies. It may sound to bassy in that area.
Dec 26, 2010 | Jamo SUB 200 Subwoofer
My jamo sub 200 & pioneer vsx517 receiver is not working properly
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Dec 27, 2009 | Jamo S606 Main / Stereo Speaker
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
Jamo SUB 200 Subwoofer Logo
593 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
