When I put a CD in it, the device will immediately eject it. When I hold the player closed for a couple of seconds it will open again, but the CD will be spinning, so it is reading it. I will work after the 3rd try usually. It is a brand new player. Whats wrong?
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
SOURCE: insignia portable dvd player: disc not spinning
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
SOURCE: Locked dvd tray.
Hi SoraTotoro,
This sounds like the child lock has been inadvertently activated . Look through the manual to find the key combination to unlock it.
Hope this helps.
Spare head 2.
SOURCE: Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
There are two lock conditions for this device.
If you can't eject the disc:
Enabling removal of disc
1. Select the DVD/CD function.
2. At POWER ON condition, press and hold down the stop button and the power button on the player for at least three seconds.
(The message, "___LOCKED_" appears when the function is activated.)
If you can't operate the functions:
Enabling operation of selector and disc
2. At POWER ON condition, press and hold down the play button and the power button on the player for at least three seconds.
Hope this helps!
