When you try to start the bike, does anything happen? Noises? Clicks? Or is it silent and nothing happens? If you hear a click or it try's to start but doesn't turn over. If nothing at all happens when you hit the start switch then you most likely have an electrical issue, versus if you hear the starter click or try to start to bike, then that would mean a mechanical issue.
Could be a shift selonoid in the trans if thats where they are. I would google search it and start reading and watching videos on youtube. You will find alot of info and possibly a fix for it.
With out hearing the noise it is hard to say but it could be a wheel bearing but most of the time a bearing will hum, this could be a bad cv axle or a brake brake hitting the bracket, try to drive the car and hit the brake a little and see if the clicking goes away, if it does then i would say it is in the brakes. if it does not then have the cv axle checked.
I'm not to sure on this one but i had a very similar problem with one of my cars it turned out to the the throttle position sensor had gone bad. In my case though everything was fine till the car heated up. Then I never know what was going to happen. Most the time at lights my care would just stall when i hit the gas. I though it was a vacuum hose issue but there was no leek. If the
throttle position sensor is not working or is not working like it should then the engine will not respond to the gas pedal being hit. Or will rev real high when not being hit. I hope this helps you and solves you issue!
it is likely that your hard drive is broken internally. th noise you are hearing is the needle hitting the platter inside the drive itself, something that normally should never happen. there are a few possible quick fixes, but nothing permanent other than replacement. you can leave the drive until it is cool then try. also some people have said putting it in the freezer in a ziplock bag for 15minutes will work, as moisture can damage the drive as well i do not recommend it
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
