It spins but always has standing water and smells
SOURCE: Washer will not drain properly.
The splashing you hear is a liquid thats in the balance ring. This is located at the front edge of the inner tub that you spun by hand. It helps balance the loads. This is normal. The smell is a problem inherent to front loaders. About once a month run hot water wash with a cup of bleach in it, no clothes. Best bet is to leave door open to allow air to dry interior. I removed bulb in mine.
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
SOURCE: LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
SOURCE: Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Hi
The smell usually comes
when the washer is unable to drain water completely, you can run your washer at
its hottest temperature setting with 1 cup of vinegar inside the unit. After
this take off the bottom front panel and clean it completely, also clean the
drain hose and drain pump filter, the smell should disappear after doing all
this. Hope this helps...please post back for further assistance.
Daniel
