I cleaned both ovens a couple of days ago. When I tried to use the lower oven today, it would not heat. This occurs with BAKE and BROIL settings. The upper oven works fine. On BAKE, I set the temperature, it shows PRE- BAKE on and temp. Reads 135. I can also hear what I think are 2 separate sounds of relays (?) clicking. Any help would be much appreciated.
To me, although it's possible, it would be unlikely that both element are burnt out as you said bake and broil doesn't work. Most likely a control issue or a fuse if your model has one.
Element is burned out.
Search Over 2 1 Million Appliance Parts
Sears Online In Store Shopping Appliances Clothing More
Hello
& Welcome to FixYa
First,
unplug it for 30 minutes and if the problem returns then it means that the door
lock assembly is bad & needs replacement. Please get back to me if you have
any other questions.
Kevin
