Hey. I have a silver razr v3m from verizon, and for some reason, whenever i turn it on, the screen is all messed up. The screen is entirely white and i cant see anything. You can hear the buttons beep, but the screen isnt working. I got a new razr, but i wish i can get the pictures and videos off of it.
Can anyone tell me whats going on and if there is any way to fix this?
That is a software issue. You need to either contact motorola or verizon regarding that issue. This is a known problem with their phone and they never fully resolved the first batch of the Razor freezing issue.
the
OPCODe can master reset the phone. I screwed up my phone by trying to
change the theme and evry time i pressed menu the phone restarted.
However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my
phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my
contact and my picture gallery were not affected. (Make sure you key
the command in exactly. 18*1 is Master Clear, and you don't want do to
that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might
have to push CLR a few times to clear the number you entered to get
into OPCODE mode.
It was really helpful
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
My friend, Verizon is the worst company that makes bluetooth useless, The reason why this is? is because Verizon has its V cast music going, so they disable verizon phones to be able to transfer music or pictures phone to phone via blue tooth, this sucks i know, i dont think u can even put music using motorola phone tools as verizon phones has a totally different interface,
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
