Serial Number A4-328151 what is the date manufactured?
Contact Maytag to discover the date of manufacture.
Go to the following Maytag link and register your machine to be able to contact their support team who will be able to assist you.
https://www.maytag.com/webapp/wcs/stores/servlet/WHRContentDisplayView?storeId=10212&catalogId=10562&langId=-1&cid=owners-center_register-a-product-main&krypto=sqdAqL3AET%2FEUYYriSpvq9Rrpe7W27gG%2FoOExoH0ul8%3D&ddkey=https:OCUserRedirect
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
SOURCE: Maytag LSG7800AAW Dryer not working
Its Either One Of Two Problems If Its Electric Its The Thermostat but if its gas it can be either the thermostat or the igniter. If its gas you can watch the igniter or listen to hear if its lighting. If it lights its the thermostat cause if the thermostat is malfunctioning it will turn the gas off when it doesn't detect the flame. It turns the gas off to prevent your home from filling with gas. Hope this helps.
Thanks For Choosing Fixya
Sincerely,
Michael Scott
SOURCE: Maytag Gas Dryer LSG7800AAW makes noise at start up
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
789f
SOURCE: can't find value or date of manufacture of wringer washer(maytag)
I have a 1936 maytag gyratator wringer type electric washing machine in very good condtion - it works like a charm. What is it worth? I am out of room to continue storing it inside and it too good to leave outside - all the decals on it are like new with the exception of the bottom of the one with the years of maunfacture on it - it goes from 1922 to 1936
SOURCE: I need a model number
Hi
Whirlpool currently have two models under production-- LTG5243DQ & LTE5243DQ. You can check out these models at this link--
Whirlpool Washer/Dryer Stacked Combo Models
If you have a different washer model then check out the model# at these locations---
Hope this helps... Please post back if you need more information.
Daniel
