Bosch Master
- Posted on Dec 25, 2008
Re: Drum makes loud whinning noise when spinning at high...
Remove drive belt.and turn drum by hand, if it feels rough or sounds noisy, then the main drum bearings have failed., also check that the main drum pulley is not loose. If you think it is the bearings, then it is quite an expensive repair.
Plz rate this solution.Thanks.
