My leaster L-MAX keeps saying "it you see your name, touch it with the pen... I can't t get it to read the pen's input...any suggestions?
You need calibration
Touch Screen Calibration is as:
1.) Ensure that a cartridge is NOT inserted.
2.) Hold down the Hint (’?') button while turning the unit on.
3.) When the LEAPSTER menu screen appears, press the ‘A’ button.
4.) Touch each of the crosshairs that appear with the stylus.
5.) Restart the unit.
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
When asked "if you see your name touch it with the pen", all of the names go green intead of stay yellow and when you touch the screen with the pen nothing happens
same problem. "if you see your name, touch it with the pen" yet nothing happens. tried new batteries, installing with usb.. still no luck.
same thing over here., except for my leapster2. can't get past "if you see your name..."
