I have an up/down converter but have no idea how it works. The europe Volt is 230 on the coffee station.
SOURCE: jura impressa s9
you need to clean / lubricate the "plungers". The normal clean cycle will strip off the lubricant over time. See my post here:
http://www.fixya.com/support/t348905-malfunction_8
SOURCE: Jura Impressa E fails to dispense, then gives "open tap" message
I had the same problem, when I called their very helpful customer service, I was given these directions.
Take out the tray.
Inside the machine you can now see a flap hanging from the top.
Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
Wipe the filter with a paper towel.
Put the machine back together, and voila you got your coffee brewing again.
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
SOURCE: Jura Impressa F9
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
