SOURCE: I seem to be haveing
Digital watches all work from a memory chip on the movement. The most common problem is the memory is filled or corrupted when you cannot seem to re-set them. In most styles, pressing and holding all the set buttons in at the same time for three or four seconds can fix this error. The dial will clear and the time and alarms must then be reset. If not you may need to have a watch technician use the AC button inside the case on the movement. He will need to use a metal tweezers and touch the + side of the battery to the AC contact point on the movement.
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
SOURCE: INSTRUCTION HOW TO SET JR-9681
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please..
SOURCE: fossil JR-8748
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
