I have installed the latest version of Whatsapp on my Nokia X2-00 s40 phone but it shows "chat server not connected". I am a Vodafone user. My friend has Nokia X2-01 with a Vodafone sim card but it works perfectly. Please help.
If you have Airtel or Tata Docomo as your mobile provider, we have confirmed reports of successfully using WhatsApp with a specific wireless access point configuration: If you have Vodafone as your mobile provider, these steps may help: If you have Idea as your mobile provider, you may be able to successfully use WhatsApp by following these steps:
what do u meen by delete config on vodafone setting
Hi, I'm having Nokia X2-01, i downloaded Whatsapp, & when i'm tryin to connect, i'm getting error "could not connect to server: timed out", i tried different solution, but the issue is with the DATA PLAN, i.e. Kindly check whether data plan (2G or 3G) are active or not, i mean, i'm able to access internet (open websites on my phone) via GPRS, but unable to connect, as i don't have Active Data Plan but when i tried with my friend's SIM card, in which 2G Data Plan is Active & i'm able to connect with WhatsApp, Kindly check, if its working, kindly share it for helping others. Regardshttp://homepageforu.webs.com/
Hi, I'm having Nokia X2-01, i downloaded Whatsapp, & when i'm tryin to connect, i'm getting error "could not connect to server: timed out", i tried different solution, but the issue is with the DATA PLAN, i.e. Kindly check whether data plan (2G or 3G) are active or not, i mean, i'm able to access internet (open websites on my phone) via GPRS, but unable to connect, as i don't have Active Data Plan but when i tried with my friend's SIM card, in which 2G Data Plan is Active & i'm able to connect with WhatsApp, Kindly check, if its working, kindly share it for helping others. All Wabsites at 1 place, Facebook, Twitter, GMail, Yahoo, Rediff, Youtube, LinkenIn, n Many more... Just check out http://homepageforu.webs.com/
SOURCE: I have a nokia 5310. When I insert my Airtel or
hi
you are installed a security code when you are using your old sim cards
so if you wont to install a new sim card you have to know your security code
other wise
1) insert your old sim card
2) switch on the phone and back up all data
3) Connect your phone to pc using Nokia PC Suite and Data cable
4) make sure about your data
5) Download the Nokia Software updater
6) Update your phone software or reinstall if you have already latest software
if any doubt replay me
Link for nokia Software updater
http://www.nokia.co.in/support/product_support/phone-software-update
SOURCE: nokia 6300 doesn;t work with sim card
Hi there, you may try to reset the whole software on your cellphone. Provided to back up all the necessary contacts, messages on your Cellphone. There is a need to update the software version of your cellphone to make it working again.
You
SOURCE: I want to change sim card from virgin to vodafone
your service provider must give you the code.
You may tell them that you are switching providers and legally they MUST give you that code.
you could also try a local cell phone shop (generic one) and have them ask for the code for you.
SOURCE: unlock code for nokia N97mini (vodafone spain)
8 digit code? A genuine network unlock code for a Nokia N97 Mini would be 22 characters in length. If your code is requesting an 8 digit code this is the security code, however entering the correct security code will not unlock the phone for use on alternative networks.
As far as I am aware there is currently no code-based unlocking solution available for a Vodafone Spain locked Nokia N97 Mini. You would need to contact Vodafone for the code.
SOURCE: my nokia cell phone 5130c is missing
u cannot lock ur phone but u can lock block ur sim card
if ur phone cdma den ok
if not its gone
i have nokia x200 in my mobile whats app is not working i have tata docomo so what should i do
