SOURCE: Changing time on Nortel networks Phone system
Sorry, the tester012 was an accident, so I wanted to repost in case there were more questions on this.
The answer still stands for most Nortel PBXs:
To set the time and date of your system you program in load 2:
Step 1) LD 02
Step 2) STAD "Day Month Year Hour Minute Second"
i.e. STAD "24 11 1976 15 41 49" =
November 24th 1976 3:41pm 49 seconds"
To test it...
Type: "TTAD" - (this tests time and date)
But I also wanted to clarify that it is in the manual, but since there are multiple manuals with a Nortel PBX, that you need to look in the LD (or Loads) in them. This particular one is found in LD 02.
Another site to check out for a crash course in LD for Nortel (in case you have similar issues that you need assistance on) is this one here:
http://www.pbxinfo.com/meridian-systems/16288-meridian-crash-course-programming-guide.html
I hope this has been helpful, again I am sorry for not having logged in properly to be notified on more explanation when I posted Solution #1.
SOURCE: changing name in nortel T7316E handset
We would like to change the name displays on our phones
SOURCE: how to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
SOURCE: How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
