1999 Honda Civic Logo
Anonymous Posted on Sep 11, 2012
1999 Honda Civic LX Stalling/Overheating!!!
My 1999 Honda Civic LX SOHC is stalling, jittering and ****** off to say the least. (I don't know much about cars so bear with me). I've had problems of overheating previously where my car's thermostat would hit 140. I think I've fixed the issue, I've replaced the thermostat but it was still doing that and 2 hoses blew and needed to be replaced. I've had to consistently fill my radiator with 50/50 antifreeze on a daily basis to ensure it won't overheat, so far that seems to be keeping the peace. But now as of 5 days ago, I'm experiencing these new issues of stalling. Upon taking my civic into my mechanic, his meter showed that there was a misfire in the 2nd cylinder a month prior and now all 4 are misfiring. He thought it was the head gasket at first. I had just recently replaced the spark plugs with NGK Platinums, new spark plug wires and a new distributor cap. I've received many possible culprits to my problem consisting of possibly the Throttle Position Sensor, Fuel Filter/Injection, Distributor or a radiator cap. I'm financially strapped at the moment and only could afford the radiator cap which didn't solve anything, however my radiator is running on 80% water at the moment. I'm really at a loss and I feel like I've done what I could and I'm at my wits end. Please help my poor little Civic cheat death for a little longer. Thank you
Anonymous
Level 2:
  • Expert 142 Answers
  • Posted on Sep 11, 2012
Anonymous
Expert
Level 2:
Answers
142
Questions
0
Helped
54081
Points
445
1 Related Answer
Anonymous
  • 491 Answers
  • Posted on Aug 24, 2009
SOURCE: 1994 Honda Civic LX\overheating within 2 mile drive
Remove and raise upper hose at thermostat end and remove lower rad hose.
Fill rad with a hose and watch for flow from bottom rad hose and/ or bottom rad hose connecton.......water should fall though rad easily.
Honda rads are cheap.....any restriction....replace rad.
Remove thermostat....fill thermostat housing with hose and watch for water flow at bottom rad hose.
Flush good.
Remove heater hoses.......flush back and forth until a good flow is present "With heater control set to hot" if no or poor flow....replace heater core.
Stop leak can plug everything.
Also.......not likely causing over heating....but ....at your mileage,if you do not know if the timing belt has been changed.....CHANGE IT NOW!
Water pump is optional at this mileage.
Testimonial: "thank you for the very clear, step by step instructions for diagnose and remedy"
1helpful
2answers
Why doesn't this 2000 Honda civic lx turn over when everything else works inside the car?
Honda Civic Coupe Questions - car will not start. battery ok ...
www.cargurus.com > Questions > Honda > Civic Coupe
CarGurusJul 9, 2008 - Get someone to turn it over and see if it is getting spark. ... i have the same issue with my 1993 civic lx it has a 1.5 sohc non-vtec i changed ... comes wen the 2nd click of the main relay it doesn't occurs until after few minutes, few .... My 2000 Honda Civic Ex Vtec will not start, has a new tps, new throttle body, ...
Part 1 -How to Troubleshoot a No Start (1.6L Honda Civic)
troubleshootmyvehicle.com > Honda > 1.6L
Dec 31, 2012 - Difference Between a No Start and a No Crank Condition. ... can cause your 1.6L Honda Civic (Civic del Sol) to Crank but Not Start. ... In other words, the engine doesn't turn over at all. ... 1995, 1996, 1997, 1998, 1999, 2000.
98 Honda civic won't crank (PushStart) - YouTube
? 4:11
https://www.youtube.com/watch?v=X5W7OqjKB8I
Oct 21, 2013 - Uploaded by SkzDaniel
Honda Civic won't start or crank with the clutch but goes on when you push start it. ... 2000 Honda Civic LX with new battery and starter. Still will ...
? 6:34
https://www.youtube.com/watch?v=p7KAO__nM1s
Aug 21, 2013 - Uploaded by Robert SnyperMD
2000 Honda Civic LX with new battery and starter. Still will not start. ... Crank, No Start Diagnosis Honda Coil test. - Duration: 11:17. by ...
Why it stalls at stops and low speeds
accord stalling on every stop. (1/2) - EricTheCarGuy ...
www.ericthecarguy.com/.../8.../46884-accord-stalling-on-every-stop
The car runs good but stalls every time i come to a stop. ... a stop then it diesagain.only on the stops does the idle drop very low to the point of stalling.what ... only when I start slowing down and come to a complete stop RPM's go down and the cardies. ... The popular Honda Civic and Accord vehicles share many powertrain ...
1998 Honda Accord loses rpm/ stalls coming to a stop ...
honda-tech.com/honda-accord.../1998-honda-accord-loses-rpm-stalls-co...
Jan 10, 2013 - I just bought a 1998 4 cyl 2.3 L Honda Accord two days ago. ... 1998Honda Accord loses rpm/ stalls coming to a stop. .... Is clockwise high idle or low idle? all in all i probable rotated counterclockwide 1.5 or 2 turns. maybe this ...
1999 Accord, 130k+, stalls when slowing to a stop - Honda Accord ...
www.hondaaccordforum.com > ... > General > General Tech Help
Mar 10, 2010 - My fiancee's '99 Accord EX Coupe 4-cylinder automatic, with 130,000+ miles, has recently (in .... No low RPM & feeling like it's GOING TO stall.
99 Honda Accord - Strange Stalling Issues! HELP!
https://www.2carpros.com/.../1999-honda-accord-99-strange-stalling-issu...
My 1999 Honda Accord is having sporadic stalling problems. I've noticed a pattern. Itstalls while going slow speeds and stop and go traffic, etc. The engine just ...
Stalling or Low Engine Idle Speed Due to Dirty ... - Repair
When I start my 1996 Honda accord the engine seems to sputter rpm gauge revs up on its own and spits and sputters as I'm driving down the road
My sputtering & stalling 1993 Honda Accord - YouTube
? 2:12
https://www.youtube.com/watch?v=Ki2H9aq8Xis
Jun 23, 2011 - Uploaded by mdpbfly
My sputtering & stalling 1993 Honda Accord ... 1996 Acura Integra, hesitation accelerating & misfire. ... 1993 Honda Accord Start Up and Review 2.2 L 4-Cylinder ... SIR B16A Engine sputter/ power loss at higher RPM - Duration: 1:14. by ... 1994 Honda Civic Check Engine Light Code Retrieval Tutorial ...
All comments on How To Solve Honda Idle Problems ...
https://www.youtube.com/all_comments?v=L788jKEVblY
What should I do if once I turn on my Ac my idle drops as if it's gonna die, and .... to a complete stop the rpms start going up and the car accelerates on its own. ... Honda Accord LX, and my Honda just started sputtering in idle. check engine .... My cousin replaced my radiator on my 90 civic and since then my temp gauge is ...
Acceleration Bog/Sputter/Hesitation - Honda-Tech
honda-tech.com/honda-accord.../acceleration-bog-sputter-hesitation-279...
Jun 11, 2010 - 1990 Honda Accord Ex F22 209000 miles, recent alternator change When I ... When I take off from a stoplight I get a little hesitation/bogging/sputteringfeeling until about 2,000 RPM then ... My 1999 Accord had a similar problem (F18B2engine). ... It only lasted a second or so before it would actually rev up.
1helpful
Misfires
there are 50 causes of misfire. (and flooding)
50
what we do is, conduct simple tests to find what is going on.
but first do that missed , 60,000 mile tune up, it might fix the problem
in FACT , tuneups are 100% designed to what, stop misfire.
my wild guess is it flooding.
are the spark tips (all) soaking in fuel , stalled?
thats one test, and is free, for any show with basic tools.
if you need more help tell engines option and country.
gen 6 car. see quote below and why we dont know what's under your hood (your mech opens hood and goes, ahh, a............)
The sixth generation featured updated styling although less radical than previous redesigns. Suspension and engine options were available along with their first Natural Gas Powered Civic, the GX. From 1996-2000 the Civic was sold under the CX, DX, EX, EXR, HX, LX, and for Canada, SE, and Si trims; all base models were made with 1.6L engines. The EX-CX are all SOHC (Honda D engine). The CX, DX, and LX all have D16y7 non-VTEC engines; whereas the EX has a D16y8 VTEC, and the HX has D16y5 VTEC-E. The USDM Si and Canadian SiR came with a DOHC (B16A2 VTEC). The first civic SI coupe EM1 was introduced in 1999 until 2000. Europe saw a DOHC 1.6 VTI hatch and sedan and a DOHC 1.8VTI engine was available for the Domani related five-door liftback and estate..
I have a 94 honda civic lx, at first the tach and speedometer would jump and the the car would die. I replace the rotor and cap and just replcaed the distributor with a new one. The car will do good for...
I AM AN EX HONDA SERVICE MANAGER.
THE TACH AND SPEEDO MAKES ME BELIEVE A SENSOR MALFUNCTION
I NEED WAY MORE INFO, BECAUSE THE STALLING HAS A MILLION POSSIBILITIES
1helpful
I need to know how to connect the coyal wires back
For the 1998 Honda Civic 1.6L SOHC -In-Line 4-Cylinder:
For all: LX, DX, EX, GX and HX Models; VTEC and VTEC-E
Firing Order:
1-3-4-2
Cylinders:
...........(back)..........
|...4.....3....2....1...|
...........(front)
Distributor:
....(back)
..........1
........o
.................3
.....4
.....(front)
Rotation: Clockwise
Let me know if this helped, or if you have addtional questions. Feel Free to contact me at FixYa.com!
What type of engine does a 1997 honda civic LX require?
it is a 1.6l. but it can be sohc or vtec.
8helpful
2answers
What is the firing order for 1994 honda civic lx
1994 Honda Civic - 1.6 liter SOHC L4 (VTEC)
Hope helped with this (remember rated this help) Good luck.
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
