The vent hose came off so i took it all apart and cleaned all of the lent up. put it back together and it still does it. it even smells like its burning.
Were you running the dryer without the lint screen in place? sound like you got something on heating element. Also the heating element does glow orange when it's on. If it keeps on getting too hot, there is a sensor that shuts off element after a certain temp. This may not be working right. Just what I came across working on my own in the past.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
