What's the correct cable to connect the ipod touch to the Jensen 9412 and how do i get the by pass code if the unit gets disconnected from the car battery?
i have the same problem with my itouch only songs plays with my touch screen the photo and video isn't compatible. how do i enter the code? i have the same problem with my itouch only songs plays with my touch screen the photo and video isn't compatible. how do i enter the code?
You can't post conmments that contain an email address.
here is what you can use take a rca cable to 3.5 mm cable buy a fm modulator
then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod .
follow the instruction that come with fm modulator
you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod .
http://www.tintingbyfredjohnson.com
on the faceplate there should be a reset button that can be push with a paperclip give that a try and if not try to disconnect the battery again for about 10min then reconnect starting with the ground first
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen). If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
The newer generation iPods don't always work with the iPod connection kits in a lot of the car stereos. Some of the problem is due to the fact that the new generation iPods have been changed and the stereos were manufactured before the players were released so they are not compatible. I bought my girlfriend a Pioneer car stereo with an iPod control cable, and it works fine with her Nano (not the new generation Nano) and it works with my iPod Photo 60 GB but it does not work with my iPhone 2G and I read that it is not compatible with the new Nanos or the Classics. Check with Jensen to see if the model you have is compatible with the Classic and see if there is a solution to the issue. It may not be compatible with the new video portion of the Classic firmware.
how do i use the code
