Its a brand new replacment engine but cant get sparke at the plugs
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
SOURCE: Changing Spark Plugs on 1999 Honda Shadow 750
Yes, it is an 18mm plug but you will need to use the Honda Plug Tool which is part of the stock tool kit just below the seat. Use that and you will get all of the plugs out very easily.
SOURCE: I have honda EU3000is just start for 30 seconds
More often than not, you have some type of blockage or obstruction in the carburetor that is responsble for this type of problem. Removing the carburetor and disassembling so you can clean the metering passages is going to be the best solution. There are generaly two circuits on the carb. a high speed circuit and low speed circuit. Make sure all metering passages are clean for the carb. to work efficiently. Also make sure you fuel switch is "ON".
SOURCE: i have no fuel at
Make sure you have flow from the tank to the carburetor. Also, when you cleaned the carburetor, there are several jets that have to be open in order for the fuel to "flow" through the carburetor. The carburetor on this generator has a pilot jet located on the top side of the carburetor and a main metering jet that screws into the very bottom of the carburetor and will be visible when the bowl is removed. After the main jet is removed there is a main nozzle that also has holes in it that have to be open also.
Another problem that is possible is compression. If the engine does not have sufficient compression it will not "pull" the fuel into the combustion chamber on the intake stroke. Hope this helps to get you in the right direction.
SOURCE: my honda oddessey 1995, my
Hi, since you've replaced everything else, about the only thing left is the crankshaft position sensor. This is the sensor the computer uses to time the spark signals. Because this sensor is expensive, I recommend you test it first to verify it's bad before replacing. I have pasted test procedures below as well as replacement procedure in case it fails the tests. You will need an ohmmeter for the test. If you don't have an ohmmeter, you can buy one for as little as $10, or maybe you can borrow one. You will also need a timing light if you replace the sensor. Please let me know if you have questions, and thanks for using FixYa. Fig. Fig. 2: The Crankshaft Position (CKP) Sensor rotor looks like a small gear in the lower distributor housing- CRV and 1995 Odyssey models 7. Check and reset the ignition timing as outlined below. Fig. Fig. 1: The inductive lead of the timing light is placed around the No. 1 spark plug wire; and the light is aimed toward the marks on the crankshaft pulley. Fig. Fig. 2: The red ignition timing mark on the crankshaft pulley is lined up with the pointer. The two small notches on either side of the red colored notch represent the plus (+) or minus (-) 2° increments. The white notch to the far right is Top Dead Center (TDC)
TESTING CRV and 1995 Odyssey Models
CRV models: The blue and white wires. The resistance should be 300-700 ohms.
1995 Odyssey models: The blue/green and blue/yellow wires. The resistance should be 700-1,300 ohms.
REMOVAL & INSTALLATION CRV and 1995 Odyssey Models
To install:
ADJUSTMENT CRV and 4-Cylinder Odyssey Models
If equipped with an automatic transaxle, place the shifter in Park or Neutral. If equipped with a manual transaxle place the shifter in Neutral. Make sure to apply the parking brake and block the drive wheels.
Odyssey models with 4-cylinder engines: centrally located on the passenger side, under the dash. The connector has two wires; one is brown with a black tracer, and the other wire is red.
See Figures 1 and 2
The white mark on the crank pulley is Top Dead Center (TDC).
2.2L/2.3L Odyssey 2.2L models: 13-17° at 650-750 rpm
