I've entered the SP mode and performed a All Clear fuction. This occured after I rebuilt the fuser.I do not have a tec. bulliten for this copier. Any help would be appreciated.
Thanks,
Terry
What sp code did you use. It should have been 5810 or 7807.
It it came back after that you have bad thermistors or they are too far away from the heat roller.
They ride on the heat roller, no spacing.
All clear huh, wow, what error code do you have sp7-403 1 thru 10 will show you the last 10, a code of 541 thru 548 relate to fuser with the fuser out there is no gap between the hot roll and pressure roll right? -Carl
what is the error code?
