Tonight one of the halogen rings wont turn off by the nob and i have to switch off by the wall, switched back on and it fires straight up, nob doesnt appear to be controlling it anymore, any ideas? is this a nob problem or something more serious? Can i replace the hob nob (hmmm) is there a strip down manual available anywhere? Thanks in anticipation.
SOURCE: double oven will not switch on hotpoint ew91
Press 2 buttons at the same time on the the left of the the timer unit, and then press one otjher button on right of timer unit, this should bring it off auto setting.
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Hi, its an all in one oven. Double oven with built in halogen hob. I had another look at it and removed the nob and after several minutes fiddling it turned off, i put the nob back on and turned it on and it wouldnt turn off again, pulled off the nob again and took a bt longer this time but heard a click and it went off, not sure what to do next?
Just to add even with the nob off and the dial at 0, it was still staying on, after fiddling and wobbling (very technical) it did eventually turn off.
How do you replace the control??
