I have a singer ce25o embroidery machine. After adjusting the hook timing my machine sews in reverse when you press the foot pedal and when you press the reverse button it sews forward. Help!!!
I don't know a lot about that machine as I normally oy work on Berninas. I know on a Bernina you can set the machine to start in reverse. So then since it is already in the reverse mode when you press the reversing button it would then run forward. This sounds completely normal if your model has a switch or setting somewhere where you can set it to start on reverse like you can on a Bernina. You did not say anything about the machine not sewing correctly, just that it goes in reverse when you start out normally. So that makes me think there must be a way that you can set that machine to start up in the reverse mode or in the normal forward mode.It should have nothing to do with hook timing. If your hook timing was off the machine would either produce a bad looking stitch or no stitch at all with a lot of thread jams and thread brakes. Hope this helps. Bill B.
SOURCE: SINGER LIMITED EDITION-MODEL 6268
More than likely you need a pneumatic transducer. It's the part that your air tube connects to and that is what actually makes your machine run.
sewman7
SOURCE: Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
SOURCE: singer 522 starts sewing at speed without the
Undo the foot control and take out the small square suppressor and throw it away, you don't need it anymore.
SOURCE: My foot pedal started smoking on my Singer 413 Sewing Machine
Hi.
No solution I'm afraid - but it has just happened to me too on a 1975 singer 522 Machine. Like you just switched it off and am now sourcing a new pedal....did have a look inside the pedal but nothing obvious - smells horrible though and will not use until replaced.
Tried that..reversed the adjustment and then adjusted the opposite direction, or should we have moved it the same direction? (very confused) still sewing backwards...Husband thinks it is actually something electrical. the reverse switch is switching backwards.?!?!?! Really weird....
