The router's encryption (password) is configured in the router's wireless settings. Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1 The default PW = blank (just press Enter) You can now change the default admin password. You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
If you have NOT changed the default password, that is: Manufacturer
Model
Protocol
Username
Password
BELKIN
F5D6130
SNMP
(none)
MiniAP
BELKIN
F5D7150 Rev. FB
MULTI
n/a
admin
BELKIN
F5D8233-4
HTTP
(blank)
(blank)
BELKIN
F5D7231
HTTP
admin
(blank)
If you have changed it, just reset the router and use above passwords.
You can secure your wireless network wit WEP or WAP code. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 For belkin router http://192.168.15.1 or http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click
on wireless settings then enable WEP Security then add WEP code .It is
your password to connect wi fi.Then save settings and restart router. Then you can connect your wi fi network with that code. Thanks for using FixYa.
Log in to your router control panel, select Security (wireless only), choose a method of security and set the pass code. Password will then be set, and router access will be limited to those that know that passcode.
type user name as "admin" and password as "admin" or blank or "password"
then go to dhcp then enable dhcp. Also check wireless is enabled.
If you want to secure your wi fi thne configure your router as WEP in WAN settings then add wep key it is your password to connect wi fi.
Then save settings and restart the router.
Let me know if you need more assistanse. Thanks.
Just simply type 192.168.1.1 on the address bar on your browser.
And login to the router, after you've been logged in, click wireless tab. And security sections, there you will able to add/change anything in your router. Recommended also that you change your router login password.
Unless you have set a passphrase, there isn't one. When you get to the part where it asks you for a password or"phrase" just hit enter and everything should work fine. They ship from Belkin without a password in them.
a #, address was provided so you can set up your belkin utility's thru your internet browser( just type the address provided into your browser then it will ask for a security code( by default its blank just hit submit) then you should be able to control your belkin settings. don't forget to apply changes after making a change in the settings.
