Question about Toshiba Satellite C655-S5068 Notebook
Toshiba c655 Left hinge was broken. Does anybody can tell me that it is a common issue for Toshiba C655? If so, the base cover and hinge are covered under warranty?
    Problem Solver:
  • 8 Answers
Things a pos are you entering it in a show ?
Posted on Sep 10, 2012
SOURCE:
Pyrhyc
  • 2028 Answers
SOURCE: Broken Toshiba Satellite R10 hinge
Don't try to have it welded, it won't ever be right again! Your best bet on a hinge is Ebay or a computer shop in the area that sells used laptops. Don't let them sell you one if they don't have one in stock,chances are they are going to get it off Ebay and mark it up 40% just for you. This link should provide the info you need for disassembling your machine.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-R10-R15/open-computer-case-1.htm
Posted on Jun 20, 2008
Rebgagnon
  • 382 Answers
SOURCE: Need repair manual for Toshiba P105-s6024 Laptop
Here is just what you ordered. Hope this helps. Just take your time and have patience. Not very hard. Good luck and have a good day.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
Posted on Feb 10, 2009
Audioaholic
  • 376 Answers
SOURCE: want to restore back to
when it starts up hit the f11 key, or hold down the esc and / or the delete. this will only allow the mainboard (bios) to be reset.
Posted on Jan 05, 2011
  • 118 Answers
SOURCE: toshiba c655: chek cable connection!
Maybe the cables are not connected, they may be disattached to the hard disk or optical drive. You can try opening the bottom of your laptop, it usually has a hard disk vent, when you unscrew the cover, you'd see the hard disk, and you could connect it. If this doesn't help, the boot manager of the OS might be corrupted, you should insert your setup disk and choose start up repair.
Posted on Mar 15, 2011
  • 1623 Answers
SOURCE: how to restore a toshiba
there is a system partition on the laptop that allows you to return the laptop back to how you got it from the shop. Please be aware that you will need to copy anything you have on there to an external drive otherwise it will be deleted on completion of the restor. When you first switch the laptop on hit the f11 key then choose repair your computer and choose reset to factory
Posted on Mar 27, 2011
Acer aspire 5253 power button broken due to hinge
Have a repair shop or person look at this---it may be fixable now but if you keep using it the issue may get worse.
Nov 05, 2012 | Acer Aspire 5532 15.6" Laptop Original...
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
My company keeps their copier till it absolutely dies. The top lid/cover needs to be replaced. Where can I find this replacement part?
Depending on what part is bad or broken, you can get your parts from precisionroller.com
Over to the upper right is a search box. Just put in toshiba 2060 platen cover and you will get the cover and the cushion. If you Hinge is broken which is more common just search for Toshiba 2060 Hinge and you will find those.
Good Luck and Thank You for using Fixya.
Sep 02, 2010 | Toshiba 2060 Copier
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Anybody know what the tech term is for the face cover on computer
If you're referring to the plastic cover just above the keyboard and below the LCD, it's typically just called the hinge cover or power button bezel. It's the plastic assembly the covers your LCD hinges and containg the power button for powering on the laptop.
Jul 22, 2009 | Toshiba Satellite A205-S5804 Notebook
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Aug 06, 2008 | Compaq Presario V4000 Notebook
Changing out memory
On that model, the memory is under the keyboard.
Here is a good tutorial on disassembly:
Although this tutorial is for hinge replacement, you will see the memory under the keyboard in step 17.
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
Feb 11, 2008 | Toshiba A45-S121 Notebook
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite C655-S5068 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
