I cleaned my oven via self clean mode and now after the cleaning finished and everything cooled down the burners don't work. What do I do?
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
SOURCE: unable to clean my 5 yr old self clean Crosley oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
SOURCE: Frigidaire self clean oven: how long will it stay
you can set the amount of time for self clean that you want, you can also turn it off during mid cycle, but if oven is hot it will not unlock the door til it is cooled down enough, maybe 20 min to 1/2 hr. It is a safety pre-caution.
I would buy a new stove if it means that much to you cause if you clean it you will be buying a new one anyway...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
