SOURCE: Samsung 931B Monitor Screen will not stay
jane657, Hi there. Will you stop pushing the On/Off button on your lcd/fpd. It's Broke. Period. End. Finito!!! You will not fix it. However there is one test that you should do to determine hoe bad the problem is. You will need to reconnect the 931B to a known good pc that has been fully booted and has the WIN-DESKTOP or IE fixya web page showing. quickly connect the931B to the wall outlet and the PC. Turn on the monitor!!! Yes, I know it will only come on for a second..After the screen goes to BLACK, Shine a bright flashlight onto the screen at different angles, 1-2 inches from the screen. Let me know if you see something even though the screen is black. Anyway here are your options as a consumer/user. 1. Check if unit is under warranty. 2. Check withh Samsung to see if they have a SWAPOUT program. You send them your monitor+$40-$90 and they return a refurbished same model to you with a 30 day warranty. 3. Trade in for new monitor. 4. Check with local TV/Monitor repair guy who knows all there is to know about cold-cathode-fluorescent-tubes, their power-source(inverter type) and lcd monitor power supplys (SMPS) 5. Repair on your own. Not recommended for amatures with no solid state troubleshooting skills and no instrumentation for support. Bye for now. I'm louie12fix on fixya or lmistyrel@ aim.com
SOURCE: Monitor Blank screen,
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
