Original installation disk lost while moving. The program (.exe) is not found on my computer when setting my computer up after the move. THE COMPUTER IS NOT CONNECTED TO THE INTERNET AT THIS TIME. Set up via USB port. HELP!
Use a computer that has Internet connection to download the printer driver then copy the drivers to an USB memory stick and install the printer driver onto your computer using the USB memory stick.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
SOURCE: how can I install my hp photosmart 3183?. I lost my original software CD
How can install my hp photosmart 3183 . I lose my original software CD
SOURCE: i lost my software for my printer
Go to the below web page at HP's website, and then follow the links to download the CD ("Software & Driver Downloads", then a few more clicks):
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&cc=us&dlc=en&product=304431&lang=en&
That should download the entire CD - most of the software and all. Hope that helps!
SOURCE: Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1.
HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run
◄ Wait for a Minute, if the configuration screen
appears it is done else refresh the HP Cue Device Discovery
◄ Restart the
Printer
◄ 99% chances of resolution and in the other cases a proper
uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
SOURCE: HP photosmart C5580 How scan to computer?
scanning through bluetooth is not possible
bluetooth module only pairs the computer and printer and has link only to the basic driver of the computer
so you can only print from it
if you want to scan you should connect te usb cable or use a wireless upgrade kit
SOURCE: How can I install my hp photosmart 3183?. I lost
Hello.
Look at this website at Option Two, you will get the software and drivers and also guidance of how to install your HP: click here
Hope it helps.
