What does a blinking orange light mean?
A Netgear router helps your device to share one common internet connection provided by your Internet Service Provider. Each light on the Netgear router indicates one particular action. If the router is damaged or not working properly, then these LED lights will start to blink in particular or different colors. Each color light defines each issue. Netgear router blinking orange light is the common issue faced by most users. If the Netgear internet light is blinking in orange, then it means a slow internet connection. Similarly, each orange light indicates a different function. To know more about the Netgear router orange light and the steps to fix it, read the Netgear router internet light orange instructions set given below.
When you have netgear router is blinking orange problem. you should try to follow the instructions below to fix your router problem. https://www.quora.com/How-can-you-troubleshoot-a-NETGEAR-router-that-wont-connect-to-the-internet
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
SOURCE: NetGear WNDR3300 RangeMax Xbox Live Failure
Follow the below steps to configure settings on the router:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Scan for the wireless network on the XBOX and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
SOURCE: Netgear Router WNDR3300. My brother over
need to change the fuse with 6.0 AMP.
Testimonial: "Very Helpfull answeres half the problem"
SOURCE: NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
http://www.askprob.com/forums/topic/why-...
