There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Apperently this tv has a history of sound board related problems. So if you are trying to connect external speakers because you have no sound from the set then you still will be sound-less. On the other habd if you just want more sound then I would suggest using a surround sound system which will readily connect to your set.
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
When I first bought my Sharp Aquos 42 inch TV...I started having sound problems...turned the volume way up to 60 maximum and could hardly hear it.
Then after the TV was on for 4 or 5 hours, there would be crackling chirping popping noise. It seems after the TV heats up for awhile...there is MAJOR sound problems.
So I was advised to buy a Sony surround system and connect it to my TV...deactivate the TV volume and use ONLY the surround sound. I did that...but the surround audio cables are connected to the back of the TV and I get the exact SAME problem with chirping and crackling sounds after the TV heats up.
SHARP IS NOT BEING HONEST WITH CUSTOMERS.
There should definitely be a RECALL on the sound board.
Replacing it does nothing....the overheating of the TV just damages the new sound board and the TV has to be repaired again and again.
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
