D-Link Dsl-2750b Adsl2 Verizon N Wireless Router - No Power Adapter Logo
A
Anonymous Posted on Feb 09, 2018
How do i turn off the router portion on my d-link 2750
I had verizon dsl modem that didn't work so verizon sent me a new one that was a modem/router and now I can't use my ASUS modelRT-N13U wireless router to extend my wireless range. I was told that I should turn off the router part of my new router/modem but I don't know how....
dking333
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Feb 09, 2018
dking333
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
13594
Points
78
Make sure ASUS modelRT-N13U wireless router is turned on then unplug your new router wait about 30 seconds then plug it back in.
It should find your wireless router.
Here is a web site with more trouble shooting advice:
https://www.asus.com/Networking/RTN13U/
Hope this helps
5 Related Answers
Anonymous
  • 48 Answers
  • Posted on Feb 10, 2008
SOURCE: D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Anonymous
  • 381 Answers
  • Posted on May 15, 2009
SOURCE: router or modem problem
hi..try to resets the setting of router or try to open the setting of router using/type this #>192.168.1.1<thanks and good luck..^_^
Anonymous
  • 198 Answers
  • Posted on Jun 25, 2009
SOURCE: forgotten password for D-Link DSL G604T wireless router
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
Anonymous
  • 137 Answers
  • Posted on Sep 26, 2009
SOURCE: How can I extend the range of my D-Link DIR-655
You bet.
Please see the link below for an example.
http://www.pricebat.ca/D-Link-WL-DWL-G710-Wireless-Range-Extender-802-11g-54Mbps.p_10022985/
Anonymous
  • 82 Answers
  • Posted on Nov 06, 2009
SOURCE: Will my DSL 300G Modem work
it will work if the subscription would also be an adsl line. but you need to know the new providers settings including type of connection (pppoe, dhcp, etc) and the vci settings. once you place the settings correctly, it will work.
I have Dlink 2750u modem *** router. I am switching on Hathway ISP. They give DSL connection modem. How to use Dlink 2750?
Use an Ethernet cable to connect from the port on the DSL modem to the WAN/Internet port on the D-Link modem.
D-Link DSL 2750B Modem/Router keeps shuting down ?
Try a factory reset. login to your router and under setting go to factory reset. Once done you will have to set-up you device from scratch.
D LINK DSL-2640B Router's Wireless keeps disconnecting
both modem ip address same please check book the modem and install modem ip different 192.168.1.1 and 2nd 192.168.1.2
How do I get my Wireless-G Broadband Router WRT54G to work with my Verizon Westell 2200 modem. I can get internet with the modem but not with the router
HI,
Your ISP is verizon DSL.
It is very easy to set up the router with DSL.
first check if you are ale to go online when connected only to the modem.
There are 2 types of connection for DSL.
For More information Click Here
2answers
AT&T just gave me a new Motorola DSL box and I can't get my router to even find the internet which is active. I can only get the router install portion to go just to where it can't find the...
First of all using the Router Install Portion try to do a 'factory reset' or a 'reset to default'  - wait for a reboot to see if any change occur.
Next try to use the cable between your Moto Box and your LinkSys Box in a different port on the link sys. It may sound silly, but it can work very well sometimes.
Nick
Trying to get my verizon dsl to link with my linksys WRT54G route
The ethernet cable needs to be run from the dsl modem to the plug marked "internet" on the back of the router.
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
4answers
Westell 327 wireless router
you have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
2answers
Cannot connect using westel 327 from verizion --lights blinking(dsl)
If they are charging you for the use of the westel, just tell them you don't need it. I would keep using your other modem that works.
2answers
Frequent internet disconnections
Its your network problem! your network doesnt support more load at DSL lines! you must complaint to them about this! Its not hardware malfunctioning its all about network issues!
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
