No instructions to set time and date on LED Watch by INTERCREW
Instructions for Intercrew LED
Press A (Top Left) once
Press D (Bottom Right)
It should start flashing
Press B (Top Left) to adjust
Press D (Bottom left) to move thru time,date ect.
Can some make a video on how to set. i'm about to send this product back. i've used utube but all different languages. need english.
thanks
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
SOURCE: Need instructions for setting a Sharp watch model # 2092
All the settings seem to go through the start/stop button. If you
hold it down for 3 (not 2, not 4, but 3) seconds, it toggles in and out
of "set the watch mode". You can tell you are in it because the seconds
at the bottom go all blinky. Use (quick press) start/stop to move from
seconds, to minutes, to hours, to year, to month, to day. Mode
subtracts, reset adds.
To set alarms, etc, first put the watch into Alarm Mode (Mode button, again).
Use the reset button to move to the selected alarm (1-5).
Hold the start/stop button for 3 seconds to toggle into "set the alarm mode".
Quick press of start/stop moves between things to set (kind of alarm, hours, minutes).
Mode subtracts, reset adds.
3 second hold of start/stop takes you out of setting mode.
Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies.
Difficulty: Easy
Instructions
Pull the setting knob (crown) out one "tick" for setting mode.
Set the mode hand to "WT-S."
Pull the crown out one more "tick."
Press the top button on the right side of the watch for the city setting mode.
Press the lower button on the right side to "SET" the city.
Turn the crown to select a different city, which changes the time zone.
Push the crown all the way back in to finish setting the time.
Thank you for using Fixya.
