Compaq Evo D310M 845G P4 Motherboard Logo
Posted on Dec 25, 2008
Motherboard startup problem!!
Hi my pc will not startup...its going on yes but nothing on screen...i have change the ram and it still do the same only the fans that is running and i here 3 beeps.
it has onboard vga...but i have a pci vga card and the problem still there...thik my boss brake it.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Dec 25, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
662
Points
15
If your video is running off the card then remove the cable and plug it into onboard vga. Then remove the card from the slot. That should solve it then you will need to reinstall drivers for video card. If your monitor is running from onboard video then you will need to remove the card then try turning it on.
Hi My Dell XPS 1530 Screen remains black at startup
hi
if your Laptop is on and your not getting screen the you have to do two thing
1 remove RAM from the motherboard
2 remove CIMOS battery from the motherboard for 10 to 15 mints
then re fix hope fully your laptop will work
1helpful
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
PC won't startup
either your ram or cmos cell is damaged,
Firstly remove one ram and power on it
Secondly change the cmos cell which ois on the motherboard
System hangs upright after Dell logo appears
You will have to troubleshoot and find out where the fault is. Here is what I do….. First, check the Power is ON, cable is OK and IN PC, Then open PC up, and remove all power connections from everything EXCEPT the Motherboard Connector.(s) (Remember where they go, draw a diagram etc) Power the computer up, and does it switch on? NO, Then, remove the RAM, does it Boot up? YES Faulty RAM, replace. If it still does NOT then your Power Supply Unit is probably Faulty.(But it may be the motherboard) either way we need to test more with a known good power supply. With know good PSU, plug this one into the Motherboard Connection(s). Does it work, YES. Problem Solved. OK back to Frst: Because it DID go the PSU WAS OK, The MB was OK & the RAM was OK, Now then we plug in each of the other Items, DVD Hard Drive, etc, etc. One-at-a-time, until we find the one that stops the PSU. (It has protection and will "Shutdown in event of a fault") The one that stops the PSU is your culprit, replace whatever it is.
Problem with NVidia GeForce4 MX 4000.
Hi!
Your old Rage Pro is an AGP 2x, where the Nvidia is an AGP 8x.
The Nvidia is probably not compatible with your motherboard.
Also, I think Nvidia needs much more than 320 Mb ram.
Hank
NF7-S2 No POST on startup. Can Not get into Bios
In that case the motherboard itself is faulty replace it..
3answers
NFORCE3-A CPU fan & LED come on, nothing else, no beep or video
If the RAM is incompatible with your board then yes it would not allow a boot. Make sure your front panel power wire is plugged into the proper spot on the motherboard and retry. If it's the RAM then you will still have the problem. If it was the wire loose or in wrong spot then it should work. Hope this helps & please remember to rate my answer. Thanks.
PC starts up, afterlogi n locks up. Afr restart no signal to moni
Remove the RAM from socket. Clean the RAM contacts with pencil eraser & then refit RAM.
Hope this solves the problem..
2helpful
5answers
Hp motherboard startup problem!!
hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. 86c6af2.jpg
Thanks
Iqbal
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
