Have purchased Sunbeam Bread Maker and made one loaf. When I attempted to make a second loaf, the machine began beeping repeatedly and showing a HHH error code.
for my bread machine HHH means you should contact the nearest authorised service center and E01 means too hot.for my bread machine HHH means you should contact the nearest authorised service center and E01 means too hot.
You can't post conmments that contain an email address.
That usually happens when you have baked a loaf of bread and you try to bake another one too soon. Most bread machines do that to let you know the oven is too hot for your yeast to work properly. Did this happen just after baking a loaf of bread?
1- DELAY TIMER HAS A SWITCH FUNCTION THAT HAS FAILED. 2- WASH INSIDE OF BREAD MAKER WITH COLD WATER, DRY, AND TRY TO SET TIMER. 3- BREAD MAKERS ARE NOT AS POPULAR AS THEY USE TO BE, AND ARE AVAILABLE AT USED ITEM STORES FOR 15 TO 25 DOLLARS.
That is a temperature warning that is an automatic feature on bread machines.What the machine is telling you is that the oven chamber is still too hot from baking the last loaf.It does that to prevent you from starting another loaf and having that loaf fail due to the high heat killing the yeast.If you want to bake more than one loaf push the STOP button till it beeps, unplug the machine, raise the lid, and leave it open for no less than 20 minutes.It should work fine by then if not let cool off another 10 minutes.It will be cool enough by ½ an hour to start another one.
The error code for HHH usually means it is too hot, if it is has been used recently. If it has, unplug the machine, and try to wait for it to cool down with the lid open for about 15-20 minutes. If that is not the case, I would suggest you to contact the manufacturer at:
We have one and used it for years. What we found works is to take the kneading plate out before it starts cooking. Do this after the beeps to let you know when to add fruit, and the kneading has finished. This also saves bread as you do not loose a bug chunk in the bottom. Our pan is not very good any more, but we can still get the loaf out without any problems. Just need to let it cool for about 10 minutes out of the machine before attempting to take the loaf out if it is stuck.
That just means that your the oven chamber is too hot from the last loaf you baked in it. It does that because the ingredients have to be at at the correct starting temperature or you won't get a good rise. It's designed to do that.
However, ifIf you have let your machine cool off (open the lid and leave it open after baking for about half an hour) and still shows the HHH then you have a more serious problem and should call or contact Sunbeam.
