Question about FreeMotion I7.7 Incline Trainer Treadmill
Incline not working
Incline is stuck at 30 degrees. Everything else works.
The Trainer is reading; Serching for motor controler
Posted on Oct 07, 2012
SOURCE:
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
What is wrong with and how can I fix the incline on my Nordictrack commercial 1750 treadmill?
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
May 25, 2014 | Nordic Track Commercial 1750 Treadmill...
The incline don't work
1) LUBE the shaft from Incline Motor very important
2) Tight the connector that connect in the controller board motor , take the cover where the main motor is. and look for the connector.
3) Looke for some loose wires and tight.
4) Measure 110Vac in Elevation or Down, if does not have see if there are Limit swicht and test it, and replace if Do not have l.switch y use Capacitor test it if there faulty, replace.
5) If everything is Good, test the Incline motor, and see if ok, applying 110vac direclty, disconnecting all wires from the controller board motor.
If not Work, replace.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 23, 2017 | Exercise & Fitness
My Tunturi j800 is stuck in the incline position. Other than that, it works great! How can I get it down? The screen reads that it's at 0% incline.
RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE, TROUBLESHOOTING AND FIX IT.
2) you can lube the gear, shaft+ adjust the potentiometer+see the relais contact are clean it.
sincerely. God bless you
May 02, 2012 | Tunturi Exercise & Fitness
Incline raises full and wont go down,t84
1)signal false coming console or display board
2) main motor controller is faulty.
3)Pot attached of the elevation motor ,need adjustment
4) geared slip from elevation motor , carring false signal to console.
Proceed to Test it.
Dec 11, 2011 | Horizon T84 - Treadmill
My proform tl 585 is stuck on an incline. when i try to lower the incline, the button does nothing. the incline could still raise, but obviously i'd rather lower it than raise it more.
Take the cover off and inspect the wiring. Make sure all the wires from the incline motor are connected.
If all the wires are connected and everything looks OK, try the incline again.
There are only 3 wires on the incline motor, red, white and black. This machine does not rely on any electronics to operate the incline. We know the motor works, because it will go up..Likely the switch in the console is defective.
To lower the incline, reverse the black and red wires, that will make up go down and vice versa.. If that doesn't work, the motor is likely defective.
The incline motor is available, around $110. To order find the model number on the frame of the treadmill and call the service number found there. Have your model number ready (starts with "P").
The console is no longer available.
Feb 27, 2011 | Proform 585 CS Treadmill
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
The Incline is stuck at an angle
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
Feb 21, 2009 | Epic View 550 Treadmill
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
FreeMotion I7.7 Incline Trainer Treadmill Logo
269 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Marvin
Marvin
ray gallant
ray gallant
Tom Chichester
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
