Please help I am desperate as this means letting 30 enthusiastic teenagers down. I was supposed to be recording their music (at school) and my Edirol R09 is just not even turning on- just put fresh batteries in it! Does anyone have any idea who can fix it or the nearest place- to add to the problem I am in Cambodia!
SOURCE: R-09 broken, don't know where I can repair one fast in UK
Hi Igor,
You have probably long since either had your Edirol repaired or found a replacement. If the latter situation is the case, and you have your R-09 sitting around collecting dust, I might be able to help. The buttons likely did not fall off, but were pushed back into the unit. Try opening it up by unscrewing it from the bottom (First open the battery cap) and carefully opening it up. You'll lkely find the buttons pushed back into it.
I learned this after a friend dropped mine at my wedding. Determined, I set out to fix it.
Good luck to you or anyone else reading this post,
Peter II
SOURCE: Formatting SD card
I had this problem too. Some SD cards won't properly format. My trick was I formatted the card in a different device first (canon Powershot A-630) then put the card in the R-09 and formatted it again. it took about 8 seconds for a 2 gig SD card to format.
SOURCE: Edirol R-09 Recorder Controls Frozen
This is a PARTIAL solution...
I've found that if I partially remove the SD-Card, then push the power button, it then starts and continues (without freezing) to show the meters and shows "no-card", then I push the SD-Card fully and it then shows "Loading"...
From there, it can be operated. But if I try to power-up with the SD-Card installed, it freezes and ceases to obey any buttons; which requires to remove the batteries to turn it off.
Please be aware that removing OR installing the SD-Card with power-on is NOT recommended, BUT is THE ONLY way my R-09HR now can be operated. I'm contacting the factory to solve this, but in the mean time, I had to record a live concert that I had promised to get recorded, so I tryed everithing and discovered the reinstallation of the SD-Card as the only thing that allowed me to get that concert.
The SD-Card that I bought for my R09HR is a Kingston 16GB. good luck, give it a try.
Sincerely, amclaussen at [email protected]
