Four speed automatic trans...wont move from stop when put in drive. shift fine manually in first and second..when moving can be manually shifted into drive and overdrive. But wont move from stop when put in drive. Thoughts ?
Does anyone know which solnoids are suppose to be powered up ( A or B ) and at what times ? B is suppose to be powered up in third . B seems to be powered up at all times .
SOURCE: 95 nissan 4 cyl pick up timing belt life
they say 60000 miles . its better to replace the belt and be safe
SOURCE: Where is the starter on a 95 Nissan Pick-up
crawl underneath the vehicle on the passenger side, bolted to the bellhousing of the transmission
SOURCE: 88 Nissan pathfinder is stuck in four wheel low it
Do you have it in neutral? Transmission has to be in neutral to shift into and out of 4 low.
SOURCE: 1993 pathfinder w auto trans wont shift out of second gear.it does shift in overdrive mode?
It must be giving you a code as to what is going on here. It sounds like you have a bad silenoid to me. It will be inside ya trans on the valve body. Check and see what codes are comming up on it.
check ecu fuse.your problem could be vechicle speed sensor also. if you dont see any ecu check engine light fuse either blowed or bulb burned out.but if ecu not working vechicle wont shift correct.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Transmission not engaging in first
gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Vehicle only goes
in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park
and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
Engine will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Car stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come
out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic
transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car wont downshift
sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Transmission
will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
Auto wont shift
from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
Car Transmission
will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
Shift indicator
directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing
and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
Hard to shift gears on Manual
transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Automatic transmission shift lever
hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish
delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
