Description
*: ECM determines the start signal status by the signals of engine speed and battery voltage.
The ECM activates the fuel pump for several seconds after the ignition switch is turned ON to improve engine start ability. If the ECM receives a engine speed signal from the camshaft position sensor (PHASE), it knows that the engine is rotating, and causes the pump to operate. If the engine speed signal is not received when the ignition switch is ON, the engine stalls. The ECM stops pump operation and prevents battery discharging, thereby improving safety. The ECM does not directly drive the fuel pump. It controls the ON/OFF fuel pump relay, which in turn controls the fuel pump.
Component Function Check
1.CHECK FUEL PUMP FUNCTION
1. Turn ignition switch ON.
2. Pinch fuel feed hose (2) with two fingers.
1 : Air cleaner assembly
Fuel pressure pulsation should be felt on the fuel feed hose for 1 second after ignition switch is turned ON.
Is the inspection result normal? YES >> INSPECTION END
NO >> EC-466, "Diagnosis Procedure".
Diagnosis Procedure
1.CHECK FUEL PUMP POWER SUPPLY CIRCUIT-I
1. Turn ignition switch OFF.
2. Disconnect ECM harness connector.
3. Turn ignition switch ON.
4. Check the voltage between ECM harness connector and ground.
Is the inspection result normal? YES >> GO TO 4.
NO >> GO TO 2.
2.CHECK FUEL PUMP POWER SUPPLY CIRCUIT-II
2. Disconnect IDPDM E/R harness connector F10.
3. Check the continuity between IPDM E/R harness connector and ECM harness connector.
Is the inspection result normal? YES >> GO TO 3.
NO >> Repair open circuit or short to ground or short to power in harness or connectors.
3.CHECK CONDENSER-1 POWER SUPPLY CIRCUIT-I
1. Reconnect all harness connectors disconnected.
2. Disconnect condenser-1 harness connector.
4. Check the voltage between condenser-1 harness connector and ground.
Is the inspection result normal? YES >> GO TO 5.
NO >> GO TO 4.
4.CHECK 15A FUSE
2. Disconnect 15A fuse (No. 32) from IPDM E/R.
3. Check 15A fuse.
Is the inspection result normal? YES >> GO TO 6.
NO >> Replace fuse.
5.CHECK CONDENSER-1 POWER SUPPLY CIRCUIT-II
1. Disconnect IPDM E/R harness connector E18.
2. Check the continuity between IPDM E/R harness connector and condenser-1 harness connector.
3. Also check harness for short to ground and short to power.
Is the inspection result normal? YES >> GO TO 13.
NO >> GO TO 7.
6.DETECT MALFUNCTIONING PART
Check the following.
??? Harness connectors E29, B10
??? IPDM E/R connector F10
??? Harness for open or short between IPDM E/R and condenser-I
>> Repair open circuit or short to power in harness or connectors.
7.CHECK CONDENSER GROUND CIRCUIT
2. Disconnect dropping resistor harness connector.
3. Check the continuity between condenser-I harness connector and ground.
4. Also check harness for short to ground and short to power.
Is the inspection result normal? YES >> GO TO 8.
NO >> Repair open circuit or short to power in harness or connectors.
8.CHECK CONDENSER-1
Refer to EC-469, "Component Inspection (Condenser-1)".
Is the inspection result normal? YES >> GO TO 9.
NO >> Replace condenser-1.
9.CHECK FUEL PUMP POWER SUPPLY CIRCUIT-III
1. Disconnect ???fuel level sensor unit and fuel pump??? harness connector.
2. Check the continuity between IPDM E/R harness connector and ???fuel level sensor unit and fuel pump??? and ground.
Is the inspection result normal? YES >> GO TO 11.
NO >> GO TO 10.
10.DETECT MALFUNCTIONING PART
??? Harness connector E29, B10
??? Harness for open or short between ???fuel level sensor unit and fuel pump??? and IPDM E/R
??? Harness for open or short between ???fuel level sensor unit and fuel pump??? and ground
11.CHECK FUEL PUMP GROUND CIRCUIT
1. Check the continuity between ???fuel level sensor unit and fuel pump??? and ground.
2. Also heck harness for short to power.
Is the inspection result normal? YES >> GO TO 12.
12.CHECK FUEL PUMP
Refer to EC-469, "Component Inspection (Fuel Pump)".
NO >> Replace fuel pump.
13.CHECK INTERMITTENT INCIDENT
Refer to GI-42, "Intermittent Incident".
Is the inspection result normal? YES >> Replace IPDM E/R.
NO >> Repair or replace harness or connectors.
1.CHECK FUEL PUMP
2. Disconnect ???fuel level sensor unit and fuel pump??? harness connector.
3. Check resistance between ???fuel level sensor unit and fuel pump??? terminals as follows.
NO >> Replace ???fuel level sensor unit and fuel pump???.
1.CHECK CONDENSER
3. Check resistance between condenser-1 terminals as follows.
Fuel injector
Description The fuel injector is a small, precise solenoid valve. When the ECM supplies a ground to the fuel injector circuit, the coil in the fuel injector is energized. The energized coil pulls ...
Ignition signal
Description The ignition signal from the ECM is sent to and amplified by the power transistor. The power transistor turns ON and OFF the ignition coil primary circuit. This ON/OFF operation induc ...
Other materials:
Heater & cooling unit assembly
Removal and Installation COMPONENTS 1. Steering member 2. Heater and cooling unit 3. Blower unit REMOVAL 1. Discharge the refrigerant from the A/C system. Refer to HA-24, "HFC-134a (R-134a) Service Procedure". 2. Drain the engine coolant from the cooling system. Refer to CO-1 ...
On-vehicle repair
WHEEL HUB Removal and Installation 1. Knuckle 2. Baffle plate 3. Wheel hub assembly 4. Brake rotor 5. Wheel nut 6. Anchor block 7. ABS sensor 8. Parking brake cable A. Refer to PB-6, "PEDAL TYPE : Exploded View" (Pedal type), PB-7, "LEVER TYPE : Exploded View" (Leve ...
P0011, P0021 IVT control
DTC Logic DTC DETECTION LOGIC NOTE: If DTC P0011 or P0021 is displayed with DTC P0075 or P0081, first perform the trouble diagnosis for DTC P0075, P0081. Refer to EC-1191, "DTC Logic". DTC CONFIRMATION PROCEDURE 1.PRECONDITIONING If DTC Confirmation Procedure has been previousl ...
ybe it was not a fuse . Thanks for helping we with this.
