.i need ur help.my phone is blocked.its asking puk code i dont know wat is it.plz heip me..........
Call costomer care of ur service provider for puk code
Just to add on. . .
PUK is PIN UNBLOCK KEY and blocks the SIM if you enter incorrect value thrice. PUK is an 8 digit code and if you enter incorrect value for PUK for 10 times, your SIM card will block permanently.
PUK is available with your service provider
Hope it helps
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
SOURCE: i need 2 get puk code
Personal UnlocK code is a code set by the phone service provider to prevent unauthorised usage of phone's pin number.. There's only one way to get it.. Call your service provider's helpline and they'll help you for sure..
SOURCE: UNBLOCK MY PUK CODE
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1)
If you still have your packet that your Sim Card came in, you should
find your PUK number in there, if you don't have the packet, please
read bellow.
2) You must get a phone that is on the same network
as your phone and call the networks Customer Care and ask them for your
PUK number, they will ask you for your phone number, then they will
tell you your PUK number. Once you have done this, you will be able to
reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
SOURCE: my phone locked up and its asking for a PUK code
u should have got a piece of paper along with ur mobile box..... this happened cause u entered the wrong passw 3 times.. if this is not working u got to hack into the mobile halla
SOURCE: my tracfone is blocked and i need a puk code and i
you can get your puk code only from sim carrier company visit their service centre to get the puk code or call their helpline....
Dont forget to rate plz
SOURCE: phone is locked and asking for a PUK Code. Says
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
