Posted on Sep 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
49.00ff error in hp laserjet 5200
When I turned on the Printer and 49.00ff error message come. How I solve the problem
mike
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 99 Answers
  • Posted on Apr 07, 2016
 mike
Expert
Level 2:
New Friend:
Cheetah:
Answers
99
Questions
Helped
40140
Points
227
Does the same thing happen if the printer is disconnected from the network (I'm assuming that you are using an Ethernet connection) before you power-off then power-on again?
If it does, then there is a problem with the printer itself.
If not, then it may perhaps be invoked by some system sending a 'rogue' job (not necessarily a conventional print job) to the device.
Look at HP support site for the latest firmware update to your model. Regards, Mike
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on Jan 07, 2010
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Anonymous
  • 495 Answers
  • Posted on Apr 17, 2009
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
parkerguy
  • 138 Answers
  • Posted on Sep 03, 2008
SOURCE: standard top bin full error in hp 5200 tn laserjet printer
Take a close look at the flaps hanging out the exit for the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, you'll get the bin full error. The flaps on the other end (side you can't see) have little flags that sweep between photo sensors and tell the printer in the tray is full and if paper has exited the printer into the tray.
Hope that helps you.
Anonymous
  • Posted on Feb 20, 2010
SOURCE: 10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Anonymous
  • Posted on Apr 19, 2010
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
HP LaserJet Pro M1536dnf Multifunction Printer. Firmware 2 Download' Error Message Displays on HP LaserJet 1536dnf mfp
This is why doing Firmware Upgrades is so risky. The firmware tells the printer what to do when it switches on before self testing and loading software. If the Firmware is corrupt, the printer becomes a giant paperweight. Help here
Solved: HP 1536DNF Firmware Corrupt Ready 2 Download
HP Support Community https://h30434.www3.hp.com > LaserJet-Printing > td-p Jun 4, 2020 - Solved: Hi, My HP Laserjet 1536dnf multifunction printer shows the 'Firmware Corrupt Ready 2 Download' message. I have read few treads in the forum, - 7633086.
Firmware Corrupt ready 2 download - HP Support Community
Jan 19, 2017
Solved: HP Laserjet M1536ndf MFP Firmware Corrupt Error
Jul 30, 2019
LaserJet 1536dnf MFP not working - HP Support Community
May 24, 2017
How to fix the error "Firmware corrupt - ready 2 download" i...
May 15, 2016
More results from h30434.www3.hp.com
2answers
How can i solve error code 4900FF HP 5200 ?
This is occur due to few things, first you have to check your document is not corrupt, if it is ok then you need to restart your printer once.
5answers
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
1helpful
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Hp 5200 printer error messages 49.4c18
Main board problem so u can batter replace the main board.
3helpful
Error 49.4c18 hp laserjet 5200
hp 5200 printer error messages 49.4c18
2answers
Hp laserjet 5200 the attention button red light won't stop blinking
This can be a number of reasons however I would be looking for a piece of paper jammed in the printer somewhere. Is the printer giving an error message or code?
If you turn the printer off, disconnect the printer cable, wait 5 minutes & then turn the printer back on, does it then power up & go to ready?
2answers
Hp laser jet 5200 paper jam in fuser unit
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
30helpful
5answers
Dear Sir,
Thanking
Ajom Khan Hero
Al Nahr Co.Ltd
Tripoli - Libya
k24674
Grand Canyon Tech
Grand Canyon Tech
