Question about HTC HD2 Smartphone
Phone will not charge
New battery but phone will not charge
  • HTC Master
  • 14,641 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Sep 09, 2012
SOURCE:
I need to charge my htc wildfire s phone battery it won't charge it's not the battery or charger it's the socket
Probably you will have to buy an external battery charger that will charge the type of battery the HTC Wildfire is using. But if you upgraded to another HTC phone, maybe the new one is using the same battery as the Wildfire and then you can charge the old battery in the new phone and then use it in the old phone to transfer your contacts to the new phone.
Jul 31, 2014 | HTC Cell Phones
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
Can't charge my ipac 914 phone. just bought a new battery
It means the problem with your phone is not the battery.
The problem with your phone is the charging port of your phone. The charging port of your phone is bad that is why it did not charge your new battery.
All you need to do is to replace the charging port, doing this, your phone will charge.
Take care.
Apr 23, 2010 | HP iPAQ 914c Business Messenger - Windows...
Phone will not charge it has a new battery and charger
Try put the battery on a similar phone and charge with your new charger, if it charges, it means your new battery and charger are good.
The problem with the phone is the charging port, you will need to replace the charging port because it does not charge your phone battery anylonger.
Take care.
Apr 14, 2010 | Samsung BlackJack II Smartphone
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
HTC HD2 Smartphone Logo
108 people viewed this question
Top HTC Cell Phones Experts
rrackman
D. E. Hev
David Harrelson
David Harrelson
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
