Question about Samsung Cell Phones
My samsung galaxey s2 wont charge even with a new battrey
It wont charge even with new battrey. it will charge for maybe 2mins then i go bak to cheek on it and its turned off agian, ive tryed wriggeling the charger around tryed it in the wall plug , computer and laptop and still wont charge how can i fix this proplem?
    Sergeant:
  • 280 Answers
Check plug usb try to cleaning first
Posted on Sep 08, 2012
SOURCE:
  • 298 Answers
SOURCE: my samsung SGH-J700 wont turn on or charge
Time to get the ribbon cable changed. You can do this yourself with some patience after buying the cable over ebay or get it replaced at a service centre for a very cheap price.
Posted on Jul 27, 2009
SOURCE: Samsung SGH-A701 Wont charge when on the charger
Similar problem, battery ran out but cant get recharge it, sometimes the screen flashes if it take the battery out and put it back in, but then black?
Should I try an new battery or a new phone?
Posted on May 25, 2010
GrinningFool
  • 625 Answers
SOURCE: LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Posted on Jul 02, 2009
rulds2008
  • 3866 Answers
SOURCE: Samsung Intensity Wont turn on.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 26, 2010
SOURCE: okay, so i recently bought a Samsung Slyde SPH-M54...
I just repaired my son's phone with the same problem. Turns out the Micro USB connector on the phone was completely un-soldered from the PCB. I simply had to solder it back on to get the battery to charge. You will need a soldering iron with a sharp tip and a steady hand. The connector is in a tight space.
Posted on May 27, 2010
Samsung Galaxy S2 wont turn on or charge, it also wont let me do the Hard Reset,is this fixable?
May be the problem is in the battery try replacing with a new one, the battery problem is very common in samsung devices.
Apr 17, 2015 | Samsung Galaxy S2 S II I777 AT&T
Galaxy s2 wont charge shows it is
try to clean the terminal points.
if not used.
replace it with brand new terminals or good ones.
Jan 02, 2018 | Samsung Galaxy S2 S II i9100 16GB -...
How do i flash a sprint samsung galaxey s2 for use on metro
Try looking in the FIXYA section for electronics.
Mar 06, 2014 | Cell Phones
Samsung Galaxy S2 S95G will not charge
Usually this lack of charging is a faulty mini usb connector inside the SII phone or maybe the mini USB plug on the end of charger cable. If you have a friend with a working SII use their phone to verify your battery or try their good battery in your phone. This will confirm it' s a charging / battery issue.
Not sure if you did this:A workaround for a faulty mini USB conn. in the SII would to be to buy a new battery and an external battery charger with battery holder stand. Charge batteries in the stand and change the charged batteries over into the Galaxy SII as needed.
Jan 03, 2014 | Samsung Galaxy Cell Phones
Samsung galaxy S2 is freezing and wont take a charge or sometimes randomly says its charging when its not even plugged in. can I just factory reset it?
Yes you can factory reset it. There is an option in the settings menu, usually under the data submenu. It will be titles "Factory Reset" or "Factory Data Reset" or something similar.
Nov 04, 2013 | Cell Phones
How to fix charging port on a samsung galaxy s2
Hello sir!
Your phone Software is corrupted try to update the phones software with the new jelly bean, Then try these tip
Thank you
Regards
MK Sam
Aug 11, 2012 | Samsung Galaxy S2 S II I777 AT&T
My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
Apr 06, 2012 | Samsung Galaxy Cell Phones
MY SAMSUNG GALAXY S2 WONT CHARGE
Try connecting your S2 with the usb cable provided to your desktop/laptop. If it starts recharging, then it is definitely your charger thats done for. Get a new charger...
Oct 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
The unit shuts down after 2mins of playback, same thing also when charging, the led light turns off after about 2mins
It seems that the internal battery is malfunctioning
Maybe you should try get a replace or a new device
Apr 01, 2011 | Nokia BH-214 Bluetooth Stereo Headset
My alternator is over charging and damaging my battery
GET ANORHER BATTERY THE BATTREY FOR THOES CARS REQUARIES BIG VOLTS CHEEK AT YOUR AUTO PARTS PLACE THEY CAN TEST IT FOR U FOR FREE GOOD LUCK
Apr 05, 2009 | 1998 Ford Crown Victoria
Cell Phones Logo
241 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
