I have a 1600 watt audiobahn amp every thing was working fine on it but all the sudden it cut out no sound and it is in protection mode and its hot but when i unplug the rca's it goes off so i thought it was the cables so i plugged up a different pair and it still does the same thing
Recommend you contact your nearest authorized service center directly or online here:
Audiobahn Contact Church Sound Systems Audio Video Lighting Equipment...
SOURCE: amp cuts off
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
SOURCE: my amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
SOURCE: rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
SOURCE: sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
SOURCE: My blaupunkt gta 460 goes into protection
Check the speakers wires for a wrong connection,check the speakers maybe they are not support the power of the amplifier,good luck
